Aftermarket big block heads
Do you think what I'm saying makes sense? I mean from a simply money standpoint not worrying about every last ounce of hp what I'm seeing is that aftermarket heads are going to cost me about 1000-1500 more than rebuilding Gm rect ports. I'm learning as I go here this is my first big block.
Heads play a big part in how much power you'll make. I decided on the AFR 305 with hard coat for salt water use. I purchased them bare and had tthem built. Short block was a 509. Nothing crazy. Those heads flowed awesome 610hp with all accessories ( - water pump) and eddie marine manifolds.
Worth every penny IMO
+10 on the AFR's. I have had or seen the seats fall out of countless GM heads even after fresh seats have been installed. If your bent on iron get some Dart's. I do have several sets of GM iron rec port heads, 2 pair with missing seats otherwisw very nice flow numbers and 1 set in perfect condition. All have big valves, inconel ex, and have been ported by Spyder Performance that are for sale cheap.
Im also doing new power at the end of the season, 502's now torn between 509's or 540's with aluminum heads, great thread.
Its a shame you have to put all this high dollar stuff where no one can see it
