500 EFI sensor part #'s needed >
Old 07-15-2012, 11:39 AM
F-2 Speedy's Avatar
Received 3,048 Likes on 1,357 Posts
Default 500 EFI sensor part #'s needed
I bought a pair of 2000/2001 500 EFI unit's off this site and most of the sensor's ect. were pulled off before shipping them to me, so now I'm needing either the Merc. #'s or after market so I can get these put together. I think I need the following part's
1. IAC
2. IPS
3. MAP
4. IAT
5. ECT
this was a list given to me, so any HELP would be appreciated, or tell me who I can get them from, IF the Merc # can be crossed at a NAPA or Vato zone that would be cheaper.
Thanks again
F-2 Speedy is offline
Old 07-15-2012, 12:54 PM
You can look at the parts catalogs with pictures and get the discounted price and part numbers from BAM marine . Their website is go-fast.com jeff wurl
jwurl is offline
Old 07-15-2012, 01:45 PM
F-2 Speedy's Avatar
I'll take a look, ive bought some other stuff from them, wasn't that impressed with there priceing, had to wait on some of the stuff from Merc.
thnks
Old 07-16-2012, 06:39 PM
F-2 Speedy's Avatar
anyone else
Old 07-16-2012, 06:57 PM
JasonSmith's Avatar
They are all GM parts you should be able to find at NAPA if they don't have a mongoloid behind the counter.
JasonSmith is offline
Old 07-16-2012, 07:07 PM
Ram jet 502
chevrolet big block
service parts list
catalog service description
group number qty
24502619 partial 502 1
10237292 block, bare cast iron, 4 bolt main 1
12338119 *pin, dowel - rear transmission 1
12554553 *pin, dowel-timing cover (1/4" dia) 2
12558081 *pin, dowel-head (1/2" dia) 4
10105879 *pin, dowel -oil pump (1/4" dia) 2
3826504 *plug (brass freeze plug/ 41.5mm) 6
3889330 *plug water jacket (1/4" - 19 npt) 2
3999200 *plug camshaft rr bearing (2 7/8 " od) 1
444777 *plug, oil galley frt & rr (1/4" x 18 npt) 3
14090911 *plug, drain (hex head 3/8 x 18 npt) 1
0.539 12508996 *bearing, cam #1 1
12508997 *bearing, cam #2 & rr 2
12508998 *bearing, cam # 3& 4 2
6264902 *seal, #5 bearing bolt (o-ring) 1
n/s *cap, main #1,2,3,4 (4 bolt) 4
10106461 *bolt , main cap inner (1/2 - 13 x 3.5") 6
10106460 *bolt, main cap outer (1/2 - 13 x 2.78") 10
10224104 *stud, main caps inner (1/2" - 13") 4
0.096 10181306 bearing, crank (std, #1,2,3,4) 4
10181307 bearing, crank (std, rear) 1
n/s bracket, engine lift (front) 1
n/s bracket, engine lift (rear) 1
0.137 10101164 seal, rear crank (one piece style) 1
0.206 10230954 cover, front engine w/pointer (6 bolt) 1
0.213 10198910 *gasket front cover 1
10191640 *seal,front cover 1
10243771 bolt, front cover ( special shoulder) 6
0.459 17120061 lifter, hyd roller 16
10227762 rod, push (int) 8
10227763 rod,push (ext) 8
12551399 retainer, valve lifter guide 1
9440224 bolt, valve lifter guide (5/16-18 x .62") 4
0.439 12551397 guide, valve lifter 8
0.519 12366543 camshaft w/ pin 1
12554553 *pin, locator (sprocket to cam) (1/4") 1
0.724 10114177 timing chain 1
0.736 12551401 sprocket, cam 1
0.728 12550039 sprocket, crank 1
0.529 10168501 retainer, camshaft 1
14093637 bolt, camshaft retainer (1/4-20 x .5") 1
12363419 *spring, valve inner 16
* indicates part is included in up assembly listed just above (*)
gm performance parts crate engine parts list 1
ram jet 502
chevrolet big block
service parts list
group number qty
9424877 bolt,cam sprocket (5/16-18 x 3/4") 1
10114166 key, crank sprocket 1
0.603 10198922 rod, connecting asm w/bolts 8
14096148 *bolt, rod (7/16-20 special shoulder) ar
3942410 *nut , rod (7/16-20) ar
0.616 10181277 bearing, rod (std) 8
12533507 piston w/pin & rings (std, 8.75 to 1 comp) 8
12524293 *rings, piston (std) 1
0.646 10183723 crankshaft (1053 steel) 1
3701679 *pin, flywheel locator (7/16" dia) 1
0.659 10216339 damper (8" dia) 1
10114166 key, crankshaft damper 1
10126796 bolt, balancer (1/2-20 x 1.38") 1
3864814 washer, crankshaft balancer 1
0.666 10185034 flywheel (automatic) 1
3727207 bolt flywheel 8
1.426 10240721 pan, oil (6 quart) 1
24100042 *plug, oil pan drain 1
3536966 *gasket, drain plug (o-ring) 1
14097040 baffle, oil deflector 1
94222917 nut, oil pan baffle 5
382105 washer, oil pan baffle(3/8" - 16) 5
9440224 bolt, oil pan (5/16 - 18 x .62") 20
1.429 10106407 gasket, oil pan 1
1.629 12555167 pump, oil w/ pick-up screen 1
3998289 shaft , oil pump drive w/ retainer 1
3764554 *retainer, oil pump drive shaft 1
1.855 3853870 fitting, oil filter 1
3866604 stud, oil pump 1
12363390 head cyl comp.w/valves (alum/oval port) 1
12363399 *head. W/semi finished seats & guides 1
12363394 *seat, intake valve (semi finished) 1
12363395 *seat, exhaust valve (semi finished) 1
12363396 *guide, intake valve (semi finished) 1
12363397 *guide, exhaust valve (semi finished) 1
12366987 *intake valve (2.25") 1
12366988 *exhaust valve (1.88") 1
12495690 *valve stem seal kit 1
12366993 *valve stem seal (int & exh) 16
12495691 *spring valve kit 1
12366989 *spring valve outer 16
12495688 *retainer valve spring kit 1
12366990 *retainer valve spring 16
gm performance parts crate engine parts list 2
ram jet 502
chevrolet big block
service parts list
group number qty
12495689 *key, valve spring cap kit 1
12366992 *key, valve spring cap 32
12366991 *shim, valve spring ar
3921912 *stud, rocker arm (7/16") 1
3860038 *guideplate, push rod 1
12368082 arm, rocker w/ ball & nut 16
12338047 *ball, rocker arm 1
3896648 *nut, rocker arm ball 1
12495488 cover , valve rocker arm (pair) 1
14096998 *oil fill cap 1
10198941 *grommet, valve cover tube 1
10198949 *grommet, valve cover pcv 1
25520079 *bolts, rocker cover 14
14085759 gasket,rocker arm cover 2
12366994 decal, eng display (502w/perf parts logo) 2
12367779 bolts, cyl head w/washers(complete set) 1
12367329 *bolt cyl head (7/16-14 x 5.08") 8
12367330 *bolt cyl head (7/16-14 x 4.06") 24
12367331 *bolt cyl head (7/15-14 x 2.06") 8
14011040 *washer special 40
12363411 gasket, cyl head 2
12368081 rod, valve push kit (intake & exhaust,3/8") 16
10227762 *rod, intake 8
10227763 *rod, exhaust 8
12363238 lift bracket, engine 2
9442448 *bolt engine lift bracket 2
12346004 loctite sealant 1
12368084 oil pump primer (pre-lube tool) 1
12557083 oil level indicator(dip stick) 1
12550533 oil level indicator tube 1
274244 o-ring seal for indicator tube 1
3.265 12555320 shield, intake manifold oil 1
12464482 manifold, lower intake 1
12366985 gasket kit, intake 1
12367959 bolt package, intake 1
17090919 injector, fuel 8
17113222 retainer kit, fuel injector 1
17120039 rail, m/port f/inj fuel 1
9440033 bolt/screw eng wrg harn clip 6
14096659 bolt/screw - cr/shf rr oil seal 2
17113517 regulator asm, fuel pressure 1
25179285 retainer, fuel pressure regulator 1
gm performance parts crate engine parts list 3
ram jet 502
chevrolet big block
service parts list
group number qty
3.67 12489493 module asm, eng control 1
2.383 10456208 sensor asm, knock 1
3.682 12146312 sensor, eng cool temp 1
2.363 10108445 gasket - ign distributor 1
2.361 1104060 distributor asm, eng 1
10096197 clamp-ign timer distributor 1
9440071 screw .375 x 1.00 flg hd 1
2.27 25164642 sparkplug 8
12368383 wire kit, splg 1
12495502 retainer pkg, splg wire 1
1.051 12494151 pump kit, water 1
8.9 9441560 bolt - flanged hex head 3
9440355 bolt/screw 1
8.866 6272959 connector, therm bypass hose 2
1485552 hose, water heater .750 i.d. 1
1470030 clamp, worm type 2
1.246 10202456 thermostat 1
10108470 outlet, water 1
10105135 gasket, water outlet 1
8.9 9440071 screw- .375 x 1.00 flg head 2
4.05 12489595 bracket, trans cable 1
12490259 bolt/screw throt cbl brkt 1
12489596 bracket, trans&throttle cbl 1
12490259 bolt/screw throt cbl brkt 2
12489597 rod, throt control 1
9411893 nut, ty/a wa ins prev tor 10.000 2
1115315 coil, ign 1
9000852 motor asm, start 1
12338064 bolt/screw, starter motor 2
12368084 primer, oil pump 1
6487532 valve, pcv 1
8.962 9438373 hose, fuel - oil evap 3/8" x 24' 1
12486610 manual, service 1
12489400 tool, diagnostic trouble code 1
12490505 manifold, upr intake 1
12489372 gasket, upper intake 1
12490255 bolt/screw, intake manifold 8
12487372 hose, fuel feed 1
22514722 seal - o - ring 1
12487373 hose fuel return 1
10216948 tube asm - fuel pressure reg vac 1
12489494 harness, engine wiring 1
gm performance parts crate engine parts list 4
tunertech is offline
Old 07-16-2012, 08:04 PM
JasonSmith's Avatar
Ben, he doesn't need to build a new engine, but good pull!
Old 07-17-2012, 11:42 AM
yeah a little over kill but it will give the other a place to scrape the info and save it
