no water to engine with bravo1 >
Old 07-28-2012, 03:24 PM
Default no water to engine with bravo1
Is there a pump in a bravo? I was to understand there isn't, but the sea pump is spinin' and there is no water going to the engine. Should I pull off the sea pump or am I starting in the wrong place?
Thanks.
spunner is offline
Old 07-28-2012, 04:09 PM
When mine was'nt pumping water, the sea pump was NFG. Had it rebuilt and good to go. Appx. 4hr. total.
Jeff
sbslinde is offline
Old 07-28-2012, 04:17 PM
Likely the impeller on the sea pump. If by any chance you hit bottom and sucked up sand/mud it may be plugged
Drock78 is offline
Old 07-28-2012, 05:35 PM
Yessir, the sea pump was NFG. Also found sand in the block and both freeze plugs popped. Also discovered the thermostat was MIA
spunner is offline
