Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 4 of 4
  1. #1
    My Boats:
    29 fever
    Join Date
    Jul 2012
    Location
    NY
    Posts
    10
    96 fever high water temp
    I'm new to boating and need some pointers as where to start trouble shooting for a high water temperature. The light came on when I put it in the water within five minutes so I docked it and shut it down. The water pressure gauge was reading about 10 psi, but there was no water coming out of the exhaust. Any ideas??
  2. #2
    My Boats:
    '94 27 Fever
    Join Date
    Apr 2010
    Location
    Lake Texoma, OK
    Posts
    414
    With no water coming out of your exhaust...I would say the impellar on your sea-water pump is shot and needs replacing. Also...if the impellar is missing parts you will need to find the missing parts. Backflush from the oil cooler to the sea-water pump and you should find them. Good luck.
  3. #3
    My Boats:
    28' Nordic Heat|Whippled 502 Teague Platinum XR
    Join Date
    Mar 2006
    Location
    Lynnwood, WA
    Posts
    253
    could also be that you sucked up something that made it past your impeller and is blocking flow to your oil cooler (and there for motor also)
    i got some wood chips stuck in all the holes of my oil cooler completely blocking flow, once i cleared all those out i was good to go. (impeller was perfect after checking FYI)
    i have since installed a strainer to prevent this issue down the road
  4. #4
    My Boats:
    29 fever
    Join Date
    Jul 2012
    Location
    NY
    Posts
    10
    Thanks for the help. I found the sea water pump and there wasn't one single vein left on it...so I flushed lines and replaced it. Works great now!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
