Gen 5 fuel/sea pump...I need a change..
fuel pump...
http://www.cpperformance.com/p-13156...fuel-pump.aspx
regulator...
http://www.cpperformance.com/p-13163...regulator.aspx
Might as well wait until you add a blower to upgrade the fuel system. Depending on what you do, you might have to change all the fuel lines to bigger ones and add a return line to the tank. No reason to do stuff twice.
i would recommend running power thru oil pressure switch controlling a power relay to feed electric pump, larger wires and takes load off primary control circuit. same setup as diesel truck lift pump. install momentary switch as primer to get fuel, you would splice into wire after oil pressure switch(OPS)
A blower? Thats paints a whole new picture. Forget what I said about the fuel pump. You will need this fuel pump and this regulator, and if you do go with a blower...go with a Blower Shop Blower and not that B&M or Weiand crap.
fuel pump...
regulator...
fuel pump...
regulator...
As for the Weiand/B&M being crap, I will bet my a$$ nobody has produced and sold more superchargers than either one of those companies. B&M was making their own street superchargers back when Trans Am's and disco were cool.
I've got a B&M 420 Megablowers making 805HP non intercooled under 7lbs of boost, on 468 Inch pump gas motors. Underdriven 7%. Running a Holley 6 Valve self regulated mechanical marine pump with 1/2'' ports, supplys the fuel just fine.
BBCLIBERATOR, theres nothing wrong with the sea pump style fuel pump. When your ready to bolt a blower on, Keith Eickert makes a pump to fit it that will supply the fuel. And if thats not enough, CV products makes a even better pump for that.
1 Post
fixx
For starters, he doesnt need a A1000 pump and boost referenced regulator to add a roots blower.
BTW the Disco and trans am's are still cool
My TA was a chick magnet, matter of fact that's how I met my wife. With a 150 shot of Nitrous they weren't too bad either. I logged more miles over 100 in that car that all my others combined. Funny thing was, I never got a ticket in that car.
