Trim Sender
Trim Sender
Every 3-4 years I have to replace the trim sender puck on my outdrive. The drive is lubricated every year. I've never had to replace the trim limit puck. The drive is 26 yrs old. It needs to be done again. I have a drawer full of limit pucks since you have to buy both. Is this normal? The boat is only used in fresh water maybe 10-12 times a year.
Thanks, Dave
Thanks, Dave
The fact you say you have left over limit switches leads me to believe you may have spliced the new senders in .When you pull the two wires back through the plates to replace one why wouldn't you do them both .The two wires have a rubber plug that is only formed when you put them together .Surely you haven't been plugging that hole with one old one and one new one .That being said .Moisture will follow the wire through and insufficiently sealed splice and ruin the sender
1 Post
fixx
unscrew it and clean it,,,give it a few hundred turns and lube it up and put it back on...should be good for a few more years..they get a slime build up amd need to be man handled one in a whyle..
Thanks, Dave
Thanks, Dave
http://www.ebay.com/itm/130893729512...84.m1555.l2649
