Comp Cam question
Major changes from the stock Merc 350 Mag EFI/MP configuration were: Dart heads, bigger exhaust valve size, bigger cam, tiny bit more compression (.1 pt), stroker crank. Motor started and ran on a test stand with the major mods on the stock tune. Actually ran very well. I set base timing then installed bigger injectors (stock were 24 lb, new injectors were 42 lb) and it ran with the stock tune as well but was pig rich as expected when you nearly double the injector size. I then trimmed out the fuel and it runs great. Real happy with how it performs. Made minor changes to timing table.
Cam is 00483LM Crower 221/230 @.050 and .525"/.545" on 1.5 rocker, 114 LSA. Kept the ECM (MEFI 1). Motor was a 95 Mag EFI/MP motor with non-vortec heads. Kept non-vortec style to utilize the existing EFI system.
Thanks again for the feedback might pick your brain again over winter. Andy
