Livorsi tach went dead on 525 efi >
Old 08-15-2013, 01:52 PM
Default Livorsi tach went dead on 525 efi
Hey guys, I have 2 525 efi's and had a tach go bad after getting waked, the transom is really low on the boat, I read this can be do to the map getting wet. If so will it correct itself after drying out.
Any input is really appreciated.
Thanks very much
trayster is offline
Old 08-15-2013, 02:36 PM
pulll and clean your main harness,,,
TWIN-SPINS is offline
Old 08-21-2013, 03:42 PM
Thank you for the reply, are you referring to the main ecm wiring harness at the back of the motor?
Seems weird that the wiring on these motors isn't more "waterproof".
trayster is offline
Old 08-21-2013, 04:55 PM
Ten pin harness
Old 08-22-2013, 09:28 AM
Ten pin harness
Thanks once again
trayster is offline
