Meth injection on boosted engine
Has anyone used Meth injection on there engines. I have a 454 Mag with procharger 5 psi .Was thinking of increasing boost to 7psi and shoot the water Meth to it above 5psi .Anbody do this ?????????
THX
THX
Yes.....but I just use windshield washer fluid.....
Boost temps drop about 35* but I meter before the blower.....so I'm sure it's not that significant.
Jegs sells a nice injector controller.....boost referenced.
Don't buy the kit. Go to the junkyard and find a nice washer reservoir or a nice rad overflow with at least a 1 gallon capacity. The pump can be a simple windshield washer motor, and you can use a nitrous nozzle and bung on the intake pipe.
I tried one on my procharged carb 500HP never could get a small enough nozzle from cooling mist as not to kill RPM when came on...took it off, now have EFI would like to give it a shot again, not sure a washer pump would work well as not much pressure ??? although 30+ years ago i built one using that and did work so so...
