whats the difference between these two couplers
The inny is the same coupler that came on my 454 mags. If you take the bellhousing off you will see the inner plate is round and has about 8 bolts connecting it to the flywheel. The couplers with a three bolt pattern attaching them to the flywheel are what you do not want. I would take a picture with the housing off and ask again.
viper15 (02-18-2022)
thanks
Ill do that tonight
Ill do that tonight
1 Post
thanx buddy,,ill have to remember that next time you call me when you have issues with your sub tub!
if you read the discription is reads 14'' alpha coupler..i have never seen a bravo coupler that bolts to the flywheel,only that style that has studs and the flywheel and coupler mounts to them from what i have seen is either a king cobra drive and a mercruiser mr and r drive..
better a finger than something else lol
The post actually confused me because the photo of teh vagine coupler in my original post is the actual coupler.
This post says "if it looks like this its an alpha" but the photo in that link is an "outy" similar to the coupler on the 454 which is a bravo coupler for sure.
I just need to confirm if the "inny/vagina" coupler will fit my bravo
I guess I just need to try it when the drive comes back from teh paint shop?
Ill have to really stick it in!
Stimleck I have run both couplers ( one on left with the triangle mounting plate is typically on small displacement motors ) and the HD one on the right ( round mounting plate with blunt end found on large displacement apps ) behind my BBC with no issues. I changed mine when I swapped from an Alpha to a Bravo 1 for piece of mind but don't think I would have had any problem using either.
So in case anyone is around for advice the 454 coupler only had 3 bolts and came from the factory with a bravo the coupler opening wont fit the alignment tool its too tight what should I use?
