Holley 750 carb problems...boat won't idle in gear
Can you guys clarify on this modification? It's not clear to me what was changed.
Speaking of car guys, when my motor was dyno'd they had a guy in house who worked for Quick Fuel. He noted that my A/F ratio was very rich at idle. It was in the low 11's, IIRC. He slightly enlarged the air bleeds, which brought them more in line, but I think he went too far with it. Have been having the exact same problems with mine - wanting to stall in gear. Idles great in neutral, but falls on its face in gear. If this is a simple mod, I might try it before I go around swapping ignition modules to run more initial timing at idle to help with this. If I can't get to where I want to be with "easier" fixes, I may be faced with modifying my carb for screw in air bleeds to enhance tunability.
hey guys been having exact same problems with stalling when drop in gear.. Running barry grant marine 750s.front jets 78...rear 86...496 dart pro 1 alm. 320 cfm elderbrock air gap. msd ig. So let me ask a couple questions to clairify for me.
Ive always had some trouble but getting worse about dying.
Motors have always been rich at idle and low rpm plugs black .
which port do i use if i use a vacume guage ? and how much vacume am I looking for what should I expect?
The air bleeds on the top towards the outside are idle air bleeds correct? change them larger by replacing or drilling?
Talk about ignition timing ? at idle in gear out of gear ? Total. what springs and bushings in MSD?
Does Barry Grant have the ability to lower the idle circut in there metering block?
thanks and if I need to supply more info please let me know
Do not mess with the air bleeds until you have eliminated everything else.
Maximum timing advance varies by application. I have been a car guy for many years and like to see the timing set for full advance (all in) at 3000 rpm. Boats are different. I will let someone with more knowledge help with this question.
I fought the idle thing too, run 540's, Dart Pro 1, Holley 800 cfm #9022 carbs,, 76 primary/88 secondary, opened the secondary's to .020, use MSD Black Bushing, and use the Blue springs , this gives me 17 degree advance at 850-900 idle out of gear,, 35 advance total, I had been using the light silver springs for years,, when I changed to the stiffer Blue Springs it really helped keep the timing constant at idle, mine is idling very nice now in and out of gear, it took me a year of trial and error,
Good Luck
Good Luck
Sorry for the quick sidetrack but wholly crap are there alot of people in this thread with big motors that are under carbureted.
Okay, carry on....just had to get that off my chest.
540 cu. in. at 5300 rpm,,, 90 % volumetric efficiency,, mild cam, requires 745 cfm carb.,,, at 100%, which would be very rare to achieve, , it requires 828 cfm.
I may run 5300 rpm once per season if at all, usually cruise 3500 to 4500 rpm.
I may need to jet up one number but reading my spark plugs they look right on for color.
Yup, 330hp-450hp small blocks I use 750's.
450hp-550hp big blocks 850's.
550-650hp 950-1000cfm 4150's.
650+hp nice big ole 4500 Dominators.
All above some generic guidelines without getting into exact engine details. Quick example: dual planes can use more carb than single planes on same exact motor build.
