89 2.3 omc timing need big help
I working on 89 2.3 ,the timing belt slip away from the mark and boat hard to start. I replace new belt,the engine still hard to start and when it run like no idle I use timing light check the mark on pulley show away from the mark on cover like 32* I try turn distributor back to 10* the engine die wrong run.can anyone tell me what wrong
1 Post
thanks every one here help me many times. .....I got my 2.3 omc running now ,i think my point and condenser some thing wrong ,I go head swap pertronix kit for omc 2.3 ,after I install pertolnix kits engine start run good I took it to the lake run very good
Thanks for posting the updated fix. Back when I use to work on this engine many many years ago a lot times the no start or really bad idle and very poor throttle response seemed to be points & condenser related. many owners would have the wrong set up or improper gapped points and so on plus what I mentioned in post # 3. Anyways thanks for posting the fix, always like to know what happened after the fact.
