big blocks
Old 09-11-2014, 05:13 PM
SB
Received 3,115 Likes on 1,402 Posts
Originally Posted by baja h2x
About 35 psi at end of rail.
35psi is not too much fuel psi by any stretch.
I have a 1999 baja h2x recently put a 415hp in it cause motor was busted when we purchased it. It has a air motive aftermarket fuel system on a mpi set up. Should I put a new stock fuel pump and start back like factory! My problem is it loads up in no wake zones and the computer messes with the timming! Next thing you know it wont start for a while!! Just looking for some good advice cause im ready to carb and intake it and be done with it!! Runs great other than the fuel preasure not cutting back at a idle!
Sounds like this might have had a Procharged engine in the boat - or something else that needed such a high flowing pump.
By any chance does this have a water crossover in place of the recirculating pump ?
And/or does it have a t-stat ?
What water temp is this running ?
Water temp is very critical to EFI because of cold start programming, ie: fuel enrichment, and etc.
SB is offline
Old 09-11-2014, 06:05 PM
A stock regulator wont have a large enough return line to bleed off the excess fuel pressure, cause too high of fuel pressure and causing the problems he's seeing.
Guess I shouldve wrote that instead of what I did, sorry for the confusion.
I believe donzi matt is spot on
TooLateVTEC is offline
Old 09-11-2014, 06:49 PM
SB
I totally understand. And I'm with it.
SB is offline
Old 09-12-2014, 09:55 PM
It has a big nice regulator on it.
baja h2x is offline
Old 09-12-2014, 09:57 PM
It did have a super charger on it.
baja h2x is offline
Old 09-12-2014, 10:00 PM
That is the pump I got airmotive 1000 with regulator!
baja h2x is offline
Old 09-12-2014, 10:02 PM
Has thermostate runs close to 200 on plane about 50mph!
baja h2x is offline
Old 09-12-2014, 10:09 PM
Feeding the factory cool fuel system?
JRider is offline
Old 09-12-2014, 10:35 PM
No cool fuel it and pumps all there just no lines
baja h2x is offline
Old 09-12-2014, 10:36 PM
Loads up so bad the fuel burns your eyes sometimes! And leaves a black film on back of boat from rich fuel!! Made me loose intrest in it ! Love my boat always wanted a big block. I tried to do it right spared no expenses now just the little things I would like to get worked out befor ed the end of season here in ohio!! Coming soon!!
baja h2x is offline
