Maybe the dumbest question ever
The answer should be those are fugly in a I/O sportboat. Anyways Centek makes a lot in the way of mufflers and water box exhaust mufflers like whats in the pic.. Those are common in bigger cruiser style boats and some what the same design that the inboard ski boat engines use but most of them go into one long box and come out either 2 exhausts or just one out the back.
LOL Iced I do, its one of two consolations I need to provide to the wifey to keep spending money on boating.
Space for guests and no straight thru exhaust.
Sadly I cant afford 2 boats so I need to compromise with one boat and a small ball and chain
Corsa makes baffled elbows that are used by many manufactures that install thru-hull exhaust that exits out the side. I have them on my boat.
Thats actually a perfect photo because I can run mine the same way using an opening through the bottom of the swim platform or out the side like a cobalt I found some smaller metal units online and can now consider some performance exhaust. Or maybe I can go full gangsta and use pvc pipe!
[ATTACH=CONFIG]530768[/ATTACH][ATTACH=CONFIG]530769[/ATTACH][ATTACH=CONFIG]530770[/ATTACH]
I believe it was 25 outlaw vs 26 scarab here was the boat pictured.
http://www.powerboatlistings.com/view/30031
And the mufflers Boom!
Cant you just put turn downs off the pipes as shown on the pvc above? Shouldnt need mufflers and you get the sound once your on plane... or does she want it on plane also??
Since my recent engine removal/ tear down I found out that I am running "Dry" exhaust through double jacketed gil risers as seen in pics.... so the exhaust exits the boat at or below the water line but one on a plane it's not bad but water still exits through the tips.... very nice setup
LOL Nailit this is going to an embarrassing place , I should say screw it my boat my exhaust! but I kind of like the quiet option lots of times as well.
My boats a heavy slow dog and beer drinking and socializing takes up lots of the time, I just want to be able to add good heads and a cam to get som extra speed but the quiet need holds me back
p.s. a year ago I would have bolted on upgrades and grenaded my motor from reversion, thanks to the great folks on this board I am learning before spending
