Issue with no crank
Issue with no crank
I am having a issue with no crank on a 04 500efi I turn the ignition key all the warnings beep and light come on. Turn to the start postion and I get nothing. I checked I have power at starter. Anyone have any other ideas? Port engine starts no problem. I have had no issues in the past with it. Used the boat 2 weeks ago now having this issue
Thanks I advance
Thanks I advance
You have constant power? And also switched at solenoid? If so the solenoid or starter is bad... Make sure you have both power under crank, I think wire is brown or yellow
Did you pull round plug and reconnect? They get loose at tines causing issues check that first!
