Greasing a Coupler -- EXTREME DIFFICULTY - NEED URGET HELP
Once this thing get's off some how, I would check the zerk to see if it's not letting you puch grease intothru it.
I have needle attachments just for this.
I try to keep this in perspective -- It's just a boat - no flesh, bone -- Just a boat!
I'll try a couple of the suggestions (except start the engine) tomorrow and Lord willing it will come off. I'll post my results. If it doesn't come off I'll take it to the Marina and let them play with it. -- It's just a boat!
Thanks to all
3pointstar
I agree. Since the gun went on, I'm also thinking that that ball (seal) in the zerk stuxk and the gun hydraulic'd on the fitting. Anything to break the seal will work. If it's a rubber whip you could try to cut it and see if that releases the pressure.
FIRST AND FORMOST --
I WANT TO THANK ALL WHO ANSWERED (even the Harbor Freight Add- LOL) AND OFFERED SUGGESTIONS.-- I GOT THAT SUCKER OFF!!!!
I had to remove the bilge blower hoses and then play astronaut and contort myself into the bilge area. Finally after trying everything everyone suggested (except starting the motor) I took a VERY LARGE screwdriver and pried the grease fitting off the zerk-- looking at the grease fitting -- it was painfully defective -- that will be the last time for Harbor Freight anything.
Again thank you all so much for your help
Lord willing the boat will be splashed today and let the season-for me begin-
Please all be safe this year
3pointstar
3pointstar
Glad to hear you got it off. One of the best tool investments I have ever made was buying a high quality cordless electric grease gun. Between hitting all the points on the boat and then the bearing buddies on the trailer, a manual gun would wear you out. Now I have to be careful to not over grease things.
I have a grease gun at wok that is pipe with a hose on the end for hard to reach fittings, there is a sleeve over the pipe that slides over the hose so you can rock it off of stubborn zirks. Any way I was going to suggest if this happens again, remove hose as you di d and slide the smallest diameter pipe you can over it and it will rock off easily, I think most adjustable and available at napa etc.
