trim sender wiring
trim sender wiring
So while doing work on the transom assembly I noticed the senders were not looking to good so I ordered new, well last weekend I had some help available so we figured to knock out this and put things back together again, when was pulling the wires out of the loom I I came up with 2 broke off butt splice connectors instead of the merc plug, this is the trim indicator side, does it matter which way you connect them?
It's a 95 bravo deal with an single rocker on the shift lever, halfway to trim all the way to trailer.
