Where to buy 2006 496 HO water pump rebuild kit???
#32
Thanks for your time and replies. As you and anyone including myself it goes totally against for anything to seal properly on a engine to double up gaskets especially when 2 gaskets are totally different.
One is an o ring gasket and the other is a flat all the way across gasket. There is no part on any engine that I know of were you put 2 totally different gaskets of materials, size, shapes and compounds completely together to seal properly from the OEM's.
I went to JC marine website they must have changed some things from the past. I do not remember that they had an inner gasket and that other plate that does not come in the Kit.
http://www.jcmarinellc.com/water_pump_kit.htm
#33
BUP Tried to PM you but your inbox is full. Looking for a deal on two of these and some fittings if you can help?: http://www.hardin-marine.com/p-14544...rhaul-kit.aspx.
#35
Sorry I had to order them already to get them here in time for the weekend so the wife doesn't have my ass!
And we are in the "boating on a budget section" lol
#36
My kits had all 3 plates in the JC marine kit (one being the one that says not included in the kit in the pic). As I said, my impellors lasted 5 years. Seems pretty good longevity to me. No leaks in that time either. BUP is right, o ring seal is way better, but I have had absolutely 0 issues with both pumps I put the kits in. Repairs the scoring and prevents the future damage. Better than original imo.
[img][/img]
[img][/img]
#37
I had no idea that they spaced the back section to allow for impeller clearance with the second wear plate and or gasket.
Years ago I remember this kit or someones kit was Impeller, O-ring gasket, round drop in wear plate & rear wear plate and the very far rear gasket. Nothing to space back for impeller clearances. I guess I should have looked at their website way beforehand. instead of a couple days ago. .
#38
#40
So I am asking, lets just say I can get enough of you guys to throw out input as to what pump you want here to pass on some additional savings plus dropped shipped to your address would that work, lets say for about 10 to 20 or more people up here ?
Mercruiser Gen VII Hardin marine pumps that are use for the Bravo apps 2001 and up ? and with and without the pulley ?
Also any other pumps ?
Speak up - if I can get enough volume, I will pass on the savings.
Who is in for this deal and what pumps ?
