Full Marine Machine Hydraulic Steering Help? >
Old 09-15-2015, 09:38 PM
Tinkerer's Avatar
Just worked on mine tonight. Rigged up a sight glass. [ATTACH=CONFIG]545187[/ATTACH]
Attached Thumbnails Full Marine Machine Hydraulic Steering Help?-img_20150915_195921128.jpg
Tinkerer is offline
Old 09-16-2015, 01:03 AM
Received 1,821 Likes on 907 Posts
Originally Posted by boatstogo
Hey guys. Finally got the rebuilt cylinders back after extended delay by local hydraulic shop. Shafts were pitted and had to be sent out of state for chrome plating. Anyway, all installed with new hoses on outside of transom and filter checked and cleaned. System is pressurized by stock pump on 496 HO. Is there a way to spin pump to bleed system with out starting engine? Does the system self bleed by turning wheel side to side or does hose fittings need to be cracked open to expend air? Any assistance or advice is much appreciated. Thanks
Doing it with the engine running and 2 people is the easiest way. One person to keep turning the steering wheel from lock to lock and one to keep adding fluid as needed.
It will self bleed with repeated turning lock to lock.
Griff is offline
Old 09-18-2015, 06:57 AM
Thank you all for the assistance. Great forum for great advice!
boatstogo is offline
Old 09-18-2015, 07:17 AM
Old 09-23-2015, 09:23 PM
Rookie's Avatar
Received 1,206 Likes on 579 Posts
I've never bled a system. I just fill the pump with fluid, start the engine and add fluid as needed. Turn loc to loc, refill. Once the helm and system has fluid in it I turn the helm loc to loc with the engines off for a bit.
Rookie is offline
Old 09-24-2015, 08:28 AM
when you mount the helm unit to the dash, if is not perfectly flat and put on the slightest bind will make drive funky as hell, if still fells funny try loosening the the 4 bolts a little see if it changes, if it does is in the mounting and the column length...
ezstriper is offline
