SBC Where to install electric fuel pump
I'm putting together a 383 stroker and the block has no provision for mechanical fuel pump. I have an electric one and I have a wiring plan.
I am looking for ideas of best place to install the pump.
I'm thinking to bolt it to the block where a mechanical one would be. Any one have a reason for something else?
The Carter Electric Fuel Pump comes with a bracket that mounts in the spot where the Mechanical pump does.
If you use this set up I recommend that you Super Glue the electrical leads to the pump to prevent them from vibrating off the studs on the pump....trust me...it works.
I have a couple of the carters that I don't need, if your interested............pay the shipping you can have em
That's about a $300~$350 "bonus" for someone that needs them...if nobody else takes them I'll be in line...keep them for spares 'cause I'm running two of them.
