Battery help!!!!!!!!!!!!!!! Plz >
Old 04-21-2016, 07:32 AM
CNC
CNC's Avatar
I run 2 cranking batteries and one deep cycle battery. The deep cycle is for stereo only 'NOT' connected to charging system, reason being is deep cycle has to be charged by a deep cycle charger. Charged at the same rate it was discharged. Fastest way to kill a deep cycle battery is short burst charging.
Randy
CNC is offline
Old 04-21-2016, 08:43 AM
The "right" setup is a cranking battery on each and a deep cycle for your accessories. But that said, I've been running three dual purpose big guys no problem for about five years. I do however charge all three every time I get off the lake on my trickle charger. Your alternators are hard pressed to keep up with a deep cycle running a strong stereo for a period of time.
Captain YARRR is offline
Old 04-21-2016, 05:32 PM
MarkDonzi's Avatar
Hey Pete,
I am in the process of adding a third deep cycle battery. I will have one battery for each motor, then all accessories off the third battery. I'm also adding a third battery switch and battery isolator . Hope all is well!
MarkDonzi is offline
Old 04-22-2016, 12:29 AM
Received 1,811 Likes on 901 Posts
Randy
My deep cycle is used for my stereo only also. It is hooked to the #2 on both my battery switches. I can charge it off either engine.
If I run it down some, I will switch one battery switch to BOTH and split the amps between the cranking and deep cycle.
Deep Cycle Battery is 6 years old.
Griff is offline
Old 04-22-2016, 08:59 AM
Originally Posted by f_inscreenname
What I was told is deep cells are not made for cranking the same way cranking batteries are not made for slow long draws.
Two deep cycles are fine if you run them in series and use an isolator.
partlowr is offline
Old 04-22-2016, 11:30 AM
Wait! In series? that would give you 24volts! What am I missing here?
drpete3 is offline
Old 04-22-2016, 11:33 AM
Originally Posted by MarkDonzi
Hey Pete,
So why 3 switches? Thats what I already have. What is the advantage of 3 switches vs 2. Cant figure that one out
drpete3 is offline
Old 04-22-2016, 12:39 PM
...sorry I meant parallel with an isolator.
partlowr is offline
