Conventional vs Synthetic Blend 25W-40 for 525EFI
I can't begin to tell you how many years I've used Napa oil which I always thought to be valvoline. I Run engines hard with minimal problems over the years. It's interesting to hear some of the post regarding sythetic but yes perhaps coincidental. I was continplating changing over to amsoil sythetic in fresh 496's. The machine shop I use highly recommends the zinc addative and swears by it especially with today's oils especially with flat tappets.
http://www.superchevy.com/how-to/add...en-racing-oil/
When I talk about using AMSOIL, I did not want to give anyone the idea that a ZINC additive was in the AMSOIL motor oil. Yes, they do have additives. But refer to them as "proprietary". Here is some good reading on not only the Joe Gibbs oil, but some good baseline information on motor oils and usage.
So, ordered 4 gallons of OEM Merc 25W-40 4cycle oil for oil change on my two 525efis. Open the box, and they shipped 2 gallons conventional as ordered, but mistakenly sent 2 gallons of 25W-40 4cycle Synthetic Blend.
My question is, while the manual only refers to conventional, would the synthetic blend mixed with conventional be a mistake? Blend in one engine and conventional in the other?
I prefer to follow the manual to a T, but wanted to bounce it off my OSO buds!
Thanks....
Thanks....
Enjoy.
Ken
Rather than start a new thread, will just give an update/testimonial as OP. For all the non believers of the importance of changing the engine oil every 25hrs on the 525EFI like the manual says, do it at 25hrs like I did and be shocked! I was shocked at how dark the oil was at 31 hours since last change. Black color. I'm VERY easy on the engines at that, often not above 4000 RMPs. Will get done in 25 hours from now....
So, just spreading the word....
What filter are you using?
I used the synthetic blend for a while and then started to have issues with lifters. But can't say for sure if the oil was the problem. If you ask opinions on oil, you will get 1000+ different answers. Here's 1001.. I now use Valvoline VR-1 20W50 conventional in my 525EFI's and change oil and filters religiously at 25 hours.
