Cams
Old 07-30-2016, 03:37 PM
Nightlife1970's Avatar
Default Cams
Have factory original 454 mags 1988.
Redoing the heads and a valve job. Is there a cam that would give me a little bump in power. Nothing to extreme but it would be nice to get a little more power out of them?
Nightlife1970 is offline
Old 07-30-2016, 04:15 PM
Received 1,493 Likes on 807 Posts
Only one I'd personally recommend from my own personal experience if your not making any other changes would be the 454/420 hp and roller rockers.
getrdunn is online now
Old 07-31-2016, 12:27 AM
Received 1,821 Likes on 907 Posts
You really can't do any significant cam upgrade unless you have performance exhaust with longer risers
Griff is offline
Old 07-31-2016, 08:35 AM
Had the same engine and griff is correct. Crane 731 roller cam, lightning headers, port heads = 450hp.
Wilks is offline
Old 08-04-2016, 08:20 PM
Registered User
89 454 Mags and I went with roller rockers, Comp Cams Extreme Marine hydraulic cam, heads refreshed, Edelbrock RPM air gap intakes and Holley 750 carbs. I was told that the Mercury 496 exhaust would support up to about 500hp and is the route I went finding new take-offs pretty cheap. That said I saw about a notable increase in top speed.
scarab31 is offline
Old 08-05-2016, 01:20 PM
The 420 cam and roller rocker upgrade wasn't significant however was btwn 3 to 4 mph diff with same prop. Enough to make it worthy not a big gain by any means. That was with stock manifolds and risers.
