Installing HP Transom Assemblies
Charter Member #232
No way you should ever use 5200 to put one one. You will need to cut it out with a saw! Even 4200 is going to be a pain. I would go with something less then that. All I am going to do is put some around the studs to keep water out of the transom. That is all Formula did when new. Even the 4200 that they put under my steering and transom assemblies ripped off some of the laminate not he back of the boat. Luckily it will be covered back up.
Put your best foot forward!
Installed assemblies last night. Everything went as expected with the exception of a small crack on the bottom of the inner plate. Crack didn't go all the way thru...cracked on the thin side of the plate. Probably gonna leave it but man those inner transom plates are cheap garbage. These were essentially brand new plates. Junk.
Put a wide washer on surface which has an angle, the washer will deform before the stud or bolt breaks. Install the same washer on a flat surface, the washer will stay flat until the stud or bolt breaks.
The plate doesn't need to be strong only flat. If the plate is installed on a flat surface, the plate would not crack. I would suggest removing the plate and use a straight edge and feeler gauges to see what the variations are. If this is not an option, remove the nut and use a feeler gauge behind the plate to see what the gap is, noting the plate has been cracked and will not rebound fully. might be able to get away with shim stock
Just my pinion
Just my pinion
My new TA came from the factory with the gasket damaged so I added a bead of 4200. I would not have added anything if the gasket was ok but it was not.
ended up buying a new plate and shimming it. wasn't off much but it worked.
