How do I route the power steering hoses on a merchant with cooler
There are two hoses on the trs style power steering ram. One is s small diameter tube with 7/16 fitting. The other hose is a larger steel tube with a 5/8 fitting. Which hose is routed to the oil cooler and then onto the power steering pump? Which hose is the pressure side?
The low-pressure side goes through the cooler,....
