Blowers or aluminium heads and higher compression?
I had a merc 420 that I made into a 525sc. I had the ebay dart hp500 knock off intake. The blower is only about an inch taller. Anyways I did 2399 pistons, stock forged rods and crank. My heads were junk, so I picked up a set of HP500 rectangle port heads, the only difference was 2.25 vs 2.19 intake valves.
Heres the full list in a better order.
Block: Stock MK IV .060 over
Pistons: Speed Pro Forged 2399
Crank: GM Forged
Rods: GM Forged
Cam: Crane 134561 Flat Cam
Heads: HP500 Rectangle port
Valves: Manley Stainless intake with Inconel Exhaust
Springs:Crane 99896-16 springs
Rockers: Comp Ultra Pro MagnumXD
Blower: Weiand 177/ Merc525
Carb: 1050 Dominator
Exhaust: EMI Thunder.
It made 572hp @5600RPM, I dont remember the torque But I want to say over 600. I remember thinking while it was on the dyno that it could break a bravo on demand.
I have over 60 hours on the setup and it has performed perfectly. It starts easy. It idles well. I am really happy. It is thirsty though. I did gain 10mph over a 420.
Crank: GM Forged
Rods: GM Forged
All true. I went with the 525sc setup because it was merc. Plug and play. I knew accessories would bolt right up, thermostat housing would work, and jetting and boost would be right for a 454. It was just a super simple add on.
