Go Back  Offshoreonly.com > Owners Forum > Donzi
1999 Donzi 28 ZX - Exhaust, please help >
Old 12-17-2007, 01:54 AM
Default 1999 Donzi 28 ZX - Exhaust, please help
Hello, I am new so go easy guys! I just bought a 1999 28 ZX w/ the 502 ci / 500HP.
Has anyone tried to remove the factory exhaust tips? I wanted to take them off and replace them with Hardin Marine 10"straight pipes for improved flow, breathing and sound. Seams the existing factory tips with silencers are glues/sealed inplace and I am worried about spalling the gel coat on the transom if I pound/force them out. Any ideas for removing them? Anyone have any thoughts about the straight pipes? Good, bad?
Thanks alot
surprise attack is offline
Old 12-17-2007, 11:24 PM
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
We sell their tips as well as many others. The tips are usually either sealed with a rubber gasket or 4200 on the Donzi hulls. We have replaced many tips on all of thier models. If it is the gasket they usually will tap loose with some adhesive & caulk cleaner/remover & be worked out carefully. If they are caulked in they sometimes come just as easily, other times they are more aggrevating. Sometimes it can help to carefully use a piece of very thin stainless mechanics wire to carefully cut the sealer between the tip flange & transoom & then carefully pry & cut the tips slowly out.. It sometimes can be a real P I T A if they are sealed up tight.. Especially if someone replaced them once before & used 5200! On occasion if it was in tight you may get a gel crack or chip behind the tip flange near the cut out.. To help minimize that work slow, its not a race..
If you are interested in buying tips from us, feel free to call me.. Jamie / Lakeside Restorations 570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 12-18-2007, 11:11 AM
ZXXX Donzi's Avatar
Enjoy, that is a great boat. You should be able to pull the factory corsa tips and replace them with straight through tips. I did. It was a great mod. They seemed a little stuck at first but then they just popped off. Mine did not have the 5200. You will not see any difference but it will sure sound better and feel a little crisper. If you think that you really want to up the HP later then spend the extra bucks and get some heavy tips with a heavy duty flapper. I had some of the $130 tips and the internal flappers blew out once I installed the blower that I bought from Jamie.
Do you have a 500 EFI, 500 hp (carb) or the 502 Mag. What kind of speeds are you seeing?
One more thing, if you get the internal flapper, they will have a rattle. You will notice it at idle. It is normal.
ZXXX Donzi is offline
Old 12-18-2007, 03:00 PM
Get off the internet Bill........................ and go to work!
Bryan Rose is offline
Old 12-18-2007, 05:59 PM
Commercial Member
All true.. I love my Zx & yes buy a good set of tips.. jamie / Lakeside
Old 12-19-2007, 09:20 AM
ZXXX Donzi's Avatar
Did you get a chance to run that new prop before it got too cold?
Old 12-19-2007, 02:00 PM
Commercial Member
Yes, but I still have some work to do.. I am doing a 1.5" Spacer currently & will get the boat back out when the weather breaks & see how it is.. Jamie / Lakeside
mattd7
12-09-2007 12:59 AM
mattd7
11-08-2007 10:45 AM
joejohn
Donzi
2
09-17-2007 02:00 PM
26sonic
Donzi
2
06-12-2004 02:10 PM
FunHome
Donzi
3
04-15-2003 11:07 AM
Quick Reply: 1999 Donzi 28 ZX - Exhaust, please help
