OffshoreOnly Boat Classifieds Sale
Go Back   Offshoreonly.com > Owner's Forum > Donzi
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 02-13-2009, 01:11 AM   #1
Looking at 99' 28zx, few questions...
Hi everyone. I'm not new to boating but performance one's yes. Looking at a 99' 28zx, two step hull, bravo drives (120 hrs), new crate 350 mags (0 hrs, owner didn't winterize and cracked blocks). This would be my first performance boat and am looking for any suggestions on certain things I should look for before I buy this thing. Apparently they are supposed to go 70 mph +/- stock does this sound reasonable? Would definately like to get 90 out of it with prochargers if possible, don't laugh at a newbie please. Is this attainable or asking too much? Any help would be appreciated. Thanks.
TonkaLBZ is offline   Reply With Quote
Old 02-13-2009, 06:06 AM   #2
1999 Donzi 26ZX...YPM 850 SCI, 1973 Donzi X-18 w/383 Mag
Quote:
They are nice boats and have a great ride for something that size. You will get 70 or so with those engines. The hull loves big power. Adding boost to stock power will get you into the 80's. There is one with worked over small blocks and lots of boost that will run close to 100.
ZXXX Donzi is offline   Reply With Quote
Sponsored Links
Old 02-13-2009, 08:27 AM   #3
Lakeside Restorations.com
Commercial Member
The Zx is a great hull. & Bill is right they do respond well to bigger power. I have upgraded quite a few of them. They also handle the rough rather well.. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE!
LAKESIDE RESTORATIONS is offline   Reply With Quote
Old 02-13-2009, 07:26 PM   #4
I really looked high and low for a hull to run with big power. I was not looking for a race boat. I wanted a nice big cockpit, roomy cabin and good ride. I am a Donzi guy but I was told that the 26ZX was a single engine slug. I bought one and went with some big power. I don't regret it at all. My boat rides very well, is large for a 26 footer and runs WELL into the 90's. It is a nice looking boat and is big fun.
Get one and enjoy
Old 02-13-2009, 10:02 PM   #5
Typhoon SC
Shanghied! 2004 Donzi 33 ZX
Watch adding big power to the 1999 Model, depending when the boat was built she may be the older hull, the easy was to know is the windscreen more round then squared? The steps were moved on the new models late 99 but were labled 2000. the boat handles well at 72 but at 80 she just out right will try to throw you out. Damn Donzi was a 1998 and she was a single engine raceboat that was a total handfull at 80mph the bottoms were redone because of the chine walk issue. Donzi hit a homerun with the 1999 26 ZX Boat of the Year and a great hull. Now they took the same hull late 1999 and made the 28ZX and the next year was boat of the year. The 1999 was a nice boat good rough water boat and ran nice at 70-72 but don't go for more on that hull.
Shanghied Again is offline   Reply With Quote
Old 02-13-2009, 10:18 PM   #6
By looking at the pictures it seems less round. Does that make it the early 99'. I plan to add power so if the hull won't take it I might keep looking.
Old 02-14-2009, 11:04 AM   #7
Quote:
Actually the Damn Donzi was a 27ZX single engine. It was the only hull that Donzi has campaigned in F-1 racing. It is the same hull that became the 28ZX. I heard the same thing about the 27ZX step hull. My friend built up a 27ZX step (1997). He talked to Donzi as he was doing his build up because he had the same concerns. The chine walk was driven by the boat climbing up on the small pad in the back. The hull hits a transitional phase in the high 70's but once you get it on the pad all is well. It just takes enough beans to do it quickly. Donzi mentioned that this seemed to be exaggerated in the race boat since it was light in the ass end.
When Brian Rose did his 27ZX he started with around 700hp. It proved enough power to smash through the transitional phase and get all the way up on the pad. Then it ran like it was on rails. He got low 80's to 85 on 700hp with NO problems. Yes, if you hold it at 78 it will get squirrely. I have personally driven the boat through all of this and know it to be true. He is now running around 800 or so hp. His boat runs 90 easily and has run 93. It likes a little tap input in the high 80's.
I heard the same thing about my 1999 26ZX. It does not have the same lower strake as the earlier 27/28ZX but other than that it has pretty much the same running surface. We have done a side by side comparison. We will break out the tape measure this spring. I was told that my 26ZX would be totally out of control in the 90's. It is not. Now that beings said, you have to be carefull with it. If you hit a nasty side wake at speeds over 85 it can get out of shape. So will many single engines that run that fast. Any sub 30 footer that runs in the 90's should be treated with respect. Its all in the setup.
Old 02-14-2009, 01:02 PM   #8
Typhoon SC
Yes that would be the early model.
Old 02-14-2009, 01:18 PM   #9
Typhoon SC
The Donzi 27ZX was 27'7" length same hull as the 28ZX till 1999. The boat runs great with a single engine "Weight Ratio" and yes you are right between 75-80 she gets hairy and can get pulled out after 80.
The hull was changed in late 1999 the moved the steps closer together made them more mid like on your 26ZX and you can only order the boat with twin 350s or Scorpions.
Damn Donzi was actually light in the front she was designed with fiberglass insert for two people to stand and no cushions, The boat ran like a top on the water I have been in her.
If the 1999 was a single big block I would power her out but the twin small blocks extra weight will add more walk.
The only way I would power up that boat is get rid of the small tabs, but on K-Planes and full hydraulic steering.
I ran some of the fastest small boats and even had a 22ZX up to 90. My 26ZX had the engine built up and she ran 85.
The fastest I ever went in a small 27 was a kryptonite with 1200hp at 130mph. Not counting my drag boat that ran 145.
My Nephew has a 1997 27ZX with a 502 worked with a supercharger XR drive and she nails 90 but like you said you have to push her out of the 78mph range, he has no pad.
I use to sell Donzi's and went through the changes on the boats.
Old 02-14-2009, 01:31 PM   #10
Hey Frank,
Did you upgrade your 26ZX with some K-planes? I am doing this with mine this spring and am wondering about the placement. I has some real planes on my 27ZX and think that they will make a nice addition to my 26
You brought up an interesting point about the 27ZX-28ZX. Somewhere in the 27 - early 28 era there seemed to be some subtle differences in hulls. We have noticed some that seemed to have a lighter layup and it seems that some have small keel pads and some don't. I have noticed the same with the bottom strake on the back step. I guess that they were playing around with different ideas but am not sure.
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wheels off a 99' Myco Brent Medley Swap Shop 5 12-13-2008 08:01 PM
anyone have any info on the 99' 42 ft cig ??? stevemamanfountain Fountain 9 01-19-2007 02:21 PM
99' 28 Thunder HIMES(JAIME) Active Thunder 10 09-17-2006 02:58 PM
28ZX questions... dockrocker Donzi 23 01-03-2005 06:12 PM
LipShip 99' Tiger lonestar382 Cigarette 23 12-17-2004 03:11 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
