GPS Speedo antenna location
I have a 2008 35zr and my gps speedo antenna look a crap. Does anyone know where donzi mounts the antenna? It is not behind the dash panel where you would think. Thanks
Talked to chuck at the factory. The antenna is located behind the panel with the grab rail over the cabin door. It must me accessed by taking off the headliner panel just behind the door. It is probably easier to just cut the wires and install new because the wire for the antenna is in with a thousand wire loom. Although if you have the older style with the white molex plug going into the speedo. Save that plug because they are like gold. That plug isn't made anymore and needs to be reused.
