need more speed zx33 donzi
q8 is indeed a play on words for Kuwait (his location).
I don't think moving up in props from a 30 to a 32 will help him, he is only revving 5100, Merc Racing 525's are set up ideally to spin 5200 and will not bounce off a stock limiter until 5400.
IMO 32's will kill his rpm unless they are worked over a lot.
Just trim that fat girl out until you break loose then down a notch from there....
The little stickers that Merc put on the cooler read 4800-5200 rpm. Most people that own 525 EFI's like myself know that 4800 is way too low for wot. The Merc Racing 525EFI is an engine that should be run at 5200 rpm for optimal power, not 4800 rpm. The engine is very capable of turning 5400 rpm in stock form, not that i am saying to do this however....To each their own I suppose.....
1 Post
q8,,b4 you swap props you really want to see if you can get any more speed from the props you have,,i spoke to a friend and he said that you want to spin those engines at 5250 b4 they hit gaurdian mode..trim up and see what you can get out of it..dont be scared to over trim at a lower rpm,,get into a nice cruise at around and trim up until the props slip then trim back down until they bite again then ease into full htrottle and see what the boat runs for speed..i dont know your boat but they all respond differently..
