Donzi 38 ZX Engine Hatch Won't Open - Help !
Can anyone confirm or deny that there is access to some quick release pin on a 1999 38 ZX to open the hatch ? My hatch motor is not working. I can hear a light clicking from inside the engine compartment when a depress the hatch open/close switch. After a while the breaker flips. I need to get into the hatch though. Help !
Ok. Got it open ! Just had to muscle it up. Dang that thing is heavy. I have it braced. Now I need to replace the actuator motor. Can anyone direct me to a new quieter bolt on replacement hatch motor actuator ?
1 Post
make sure your battery is not dead....also some of the donzi's have a hydrolic cylinder,,seeing you pulled it up look at the lifting acuator and see if theirs a plastic hose going to it,,if so then it may be out of fluid or the electric motor is stuck,,sometimes tapping the motor will free it..i have sen this from the boats sitting over the winter and water has got into them..
