38zx Daytona factory test results
DONZI MARINE
GAS ENGINE BOAT TEST DATA SHEET
TEST # DNAZ8015L304
PORT STBD
DATE 4/2/04 IDLE OIL PSI 45 45 LOCATION SARASOTA BAY
BOAT MODEL 38 ZX WOT OIL PSI 45 40 WATER CONDITIONS 1 FT
BOAT NUMBER #15 IDLE OIL TEMP 190 195 WIND CONDITIONS 10-12 N
ENGINE MGRF MERCURY WOT OIL TEMP 185 190 AIR TEMPERATURE 73
ENGINE MODEL YWIN 575 SCI IDLE WATER TEMP 155 150 HUMIDITY 0.75
DRIVE MODEL BRAVO 1 WOT WATER TEMP 155 160 RADAR OR GPS RADAR
GEAR RATIO (X:1) 1.50 IDLE WATER PRESS PROPELLER MODEL BRAVO 1 LAB
PROPSHAFT (HP) 1100.00 WOT WATER PRESS NUMBER OF BLADES 3
RPM RANGE 4800-5200 IDLE FUEL PRESSURE 12 12 PITCH 32
X" DIMENSION 17.5" WOT FUEL PRESSURE 9.5 9.5 DRIVE TOE-IN 34"
FUEL LOAD 100 GAL IDLE VACUUM (PSI) 7 6.5 PROPELLER ROTATION INBOARD
WEIGHT FORWARD 3280 WOT BOOST 3.5 5 GENERATOR YES
WEIGHT AFT 8488 AIR CONDITIONER YES
TOTAL WEIGHT 11,768 EXTENSION BOX YES ITS
LIFT POINTS ACCELERATION TEST 6.1 6.2
TRIM TABS K-PLANES RPM TO PLANE 2700
EXHAUST SYSTEM STRAIT-THRU CRUISING RPM 3500
DRIVER SMITH RECOMMENDED PROP NO
CO-DRIVER JUNKER
MINIMUM RPM TO MAINTAIN TO PLANE 2500 RPM 30.1 MPH
MPH GPH MPH GPH
1000 RPM: 10.8 N 3.8 3500 RPM: 53.1 N 34.5 CRUISE: RPM: 3500 N
S S S
1500 RPM: 12.0 N 7.5 4000 RPM: 63.2 N 44.8 GPH 69.0 TRIM 0.45 SPEEDO
S S MAXIMUM RADAR READING 53.1
2000 RPM: 13.2 N 15.1 4500 RPM: 73.5 N 69.4
S S WOT: RPM: 5050 STBD
2500 RPM: 30.1 N 15.6 5000 RPM: 83.1 N 75.0 5050 PORT
S S MPH: N
3000 RPM: 35.4 N 23.2 5500 RPM: N S
S S GPH 150.0 TRIM 0.6 SPEEDO
MAXIMUM RADAR READING 86.5
NOTES: IDLE 7.2 MPH AT 750 RPM 2.5 GPH
FUEL STABILIZER ADDED - WINTERIZED - YES
RECCOMENDED 31p BRAVO1 LAB
TEST # DNAZ8015L304
PORT STBD
CO-DRIVER JUNKER
MPH GPH MPH GPH
S S S
S S MPH: N
