Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-26-2007, 06:34 PM   #11
'83 Stinger260
Too bad I didn't catch you before you bought it. Mcmaster-Carr has it...
74575A77
Devcon Metal-Filled Epoxy #19770, Aluminum Paste Epoxy, 6-1/2 oz Tube, Alum
In stock at $22.02 Each
Good luck with your repair!
PS- That's the right stuff by the way.
CCstinger260 is offline   Reply With Quote
Old 05-07-2007, 10:54 AM   #12
1987 Wellcraft Scarab III
I completed the repair yesterday. The stuff takes 16 hours to set so I wasn't able to test it yet. Rather than remove and replace the plug after the epoxy sets up, and risk a leak I think if it doesn't leak I'm just going to leave the plug in until the end of the season. Is there anything wrong with doing that?
Steve
siearly is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
block drain plug stripped ECeptor General Q & A 16 05-21-2008 03:49 PM
TRS puking oil out the reservoir vent...? Danny_Ocean General Q & A 5 08-15-2005 01:13 PM
Stripped out fiberglass screw hole - how to fix? BillR General Q & A 11 12-11-2004 09:45 AM
Vent hole in bow?? ThirdBird Formula 29 09-19-2002 11:16 AM
stripped head bolt hole in block excaleagle42 General Q & A 6 05-17-2002 08:58 PM
Search Engine Optimization by vBSEO 3.2.0
