Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 12-08-2007, 08:37 AM   #1
'97 27 Fountain Fever
Loss of gear lube and banging into gear
What is typical for a drive reservoir to go dry? Where does the lube go? Nothing in the hull and I don't notice any oil slick on the water.
Also, after I've run the boat for a while, my drive bangs going in/out of forward. After is sits for a bit, start up, leave the dock and it goes into gear smoothe. Seems like the drive lube is working its way out of the clutch mechanism.
Any thoughts?
Griswald is offline   Reply With Quote
Old 12-08-2007, 10:10 AM   #2
dukenrock's Avatar
You may have a bad bellows
dukenrock is offline   Reply With Quote
Sponsored Links
Old 12-08-2007, 03:32 PM   #3
Charter Member #601
Mr Gadgets's Avatar
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
Griswald,
a couple of places.. it can leak, one is the propshaft seals. If you get fishline on the shaft it will allow the lube to pass. If your drive gets too hot it will push it out past the propseals. But usually that doesnt drain the bottle. I would suspect the input shaft seal is gone. If this is an early XR, they had problems with pushing the seals out of the holder. There is a replacement seal kit for it. Gives you a new retainer and seal.
I would pull the drive and look for lube in the bellows. If it is there, then that is where the leak is.
The drive clunking into and out of when it is warm?? Well if the lube is not too low, then you have something loose in the shift mechinism, maybe. The clutch cone should be ok, but it is hard to tell with out seeing it apart.
I would pull the drive and look for lube in the bellows, then pull the back cap and look for loose things there. Next I would tear it down and inspect the shift fork and cone and gears..
Hope this helps
Dick
Mr Gadgets is offline   Reply With Quote
Old 12-08-2007, 04:20 PM   #4
Thanks, Dick.
If you remember, we had a few lengthy conversations during the summer. I blew the floor out of the upper gear and installed the new upgraded gearset. I went through the whole drive and replaced a few bearings, all gaskets and seals. We talked quite a bit about the upper bearing race for the new gears. If you remember, there was some confusion on my part about the height of the tower in the new top cap I bought. Our final decision was that it simply needed to be driven down farther.
I've had about 20hrs on it since the rebuild and the alarm went off last time out. Quick check and noticed the reservoir was just about dry. I haven't seen any fluid leaking in the bilge or anywhere.
p.s. check your PMs
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
gear lube ninetym Drives and Lower Units 5 11-06-2007 06:43 PM
Leaking Gear Lube hawkfan11 General Q & A 2 06-26-2006 12:21 PM
best gear lube. traviss General Q & A 17 03-08-2004 06:06 AM
Which Amsoil Gear Lube to Use? BAD-HABIT General Q & A 4 02-29-2004 06:32 AM
gear lube jafo272 General Q & A 8 11-22-2002 10:32 AM
Search Engine Optimization by vBSEO 3.2.0
