Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-06-2008, 04:00 AM   #1
stecz20's Avatar
I am Jersey's B!tch
switching from a #5 to #6
whats the work involved.. thanks guys...
stecz
stecz20 is offline   Reply With Quote
Old 01-06-2008, 08:17 AM   #2
Charter Member #232
Audiofn's Avatar
1979 Formula 302
Drop off the boat to a qualified repair facility, bring lots of money!!
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Sponsored Links
Old 01-06-2008, 01:06 PM   #3
CcanDo's Avatar
"Udderly Fantastic" Motion / 28 Skater 300x's / Bennington Tri-toon 350 Yam
The #5's have either two or four steering ram's. The rams serve as gussets,reinforcing the transom. The 6's have approximately the same extension from the transom as # 5's on 12" extension box's. Therefore, the 6's without the 5's steering cylinders will place a greater side torque on the gimbal point of the transom. Subject to transom condition,material thickness,material type and engine power the transom may require thickening. Also, an extra knee brace may be needed. The factory gimbal studs are for a 2 1/4" transom, longer can be machined. Transom flex can be a logical mystery. When the steering cylinder/gussets are removed that rigidity should be replaced.
The bolt pattern will be different, requiring filling the old holes and drilling new ones. The old holes can be filled with a wooden dowel or high density foam rod. Either one can be driven into the hole after coating w/ Epoxy.
The 6's, with tie bar will weigh approx. 180# more than 5's on 12" box's,w/ 4 ram steering (90#/side) . The CG change may require relocating the engines,batteries and etc.
We made a couple of drill fixtures for the # 6 gimbal. The fixtures were made on a CNC mill and are spot on. The fixtures also have # 5 holes, providing for bolting the fixture to the transom and simply drilling through collets,creating The #6 bolt holes. The two fixtures are different each other. While #5 and #6 bolt circles are identical,one will create a higher X than the other.
CcanDo is offline   Reply With Quote
Old 01-06-2008, 01:26 PM   #4
McManus Superboats!
Comanche3Six's Avatar
1998 McManus Comanche 36
http://yellowpages.superpages.com/pr...R58A%3D%3D.htm
Comanche3Six is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Switching prop rotation..... rangerrick63 Prop Talk 11 09-08-2008 01:42 AM
switching from XR to HT B-max bonecrusher Drives and Lower Units 94 01-27-2008 03:55 AM
Switching Exhaust Tips Ryan8886 Do It Yourself, Boating on a Budget 1 12-10-2007 10:50 PM
switching drive ratios awsomethunder General Q & A 5 01-19-2007 08:00 PM
Switching to Allstate Interceptor Insurance and Finance 6 01-15-2007 05:21 PM
Search Engine Optimization by vBSEO 3.2.0
