Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-23-2008, 03:23 PM   #1
bor
bor's Avatar
2007 phantom 21 ls2 403 bravo 1X 1989 hustler 32le
standard bravo gears in a imco lower?
hello,
I have a brand new bravo 1X ratio 1:50 and considering to put a 2"shorty on because I want to build the engine as low as possible in the boat to get the greavity point low as possible ,but can I use my bravo gears in the shorty (case only) or need I a complete lower?
boat is a 21 phantom
engine gm Ls 2 from a corvette
thx bor
bor is offline   Reply With Quote
Old 01-23-2008, 10:45 PM   #2
Charter Member #601
Mr Gadgets's Avatar
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
Bor,
The Imco case needs the -2" vertical shaft. If you buy the case new it comes with it. There are two special bearings that go on the vertical shaft. They are radiused were it sits against the flange.
Your propshaft, bearings and gears will fit in the new case. You can use a crush sleeve to set preload on the propshaft, I have done it before many times.
If you dont already have the lower case and shaft I can supply you with it and the special bearings. Also be willing to help you switch it over, or I can do it for you. If you want more info.. pm me. Be happy to help you out!!
Dick
Mr Gadgets is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Imco lower gears 1.50:1 hoozeyurdaddy Drives and Lower Units 3 05-26-2008 07:38 AM
bravo xr upper on standard lower? Nova 26 Drives and Lower Units 23 06-03-2007 11:37 AM
Looking for bravo lower gears HPJunkie General Q & A 10 03-01-2007 09:38 AM
Imco Lower gears Scarab28 General Q & A 6 03-27-2006 11:26 AM
Search Engine Optimization by vBSEO 3.2.0
