Bravo Upper Thrashed - Is lower worth repair? >
Old 07-03-2008, 08:18 PM
edb07's Avatar
Default Bravo Upper Thrashed - Is lower worth repair?
Upper gears in pieces with metal shavings coming out of the lower drain. Drive locked up and cracked the cap. Lower spins and rotates smoothly but you can see the metal in the oil when it drained from the lower section.
Is it worth going through the lower? Would bearings need to be replaced?
edb07 is offline
Old 07-03-2008, 09:55 PM
GO4BROKE's Avatar
I am currently using a lower from a drive that I blew the upper to smithereens. Been about 10 hours, no issues. All I did was flush it a couple times.
[img][/img]
GO4BROKE is offline
Dave1972
6
03-30-2009 04:06 PM
handfulz28
Drives and Lower Units
12
05-14-2008 02:30 PM
thedonz
Wanted
0
04-15-2008 05:39 PM
Nova 26
23
06-03-2007 10:37 AM
docmanrich37
5
09-16-2006 07:42 PM
Quick Reply: Bravo Upper Thrashed - Is lower worth repair?
