Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-20-2009, 07:16 AM   #21
1999 Donzi 22 C
Quote:
Originally Posted by HotPursuit View Post
Guess what Merc runs in there #6 drysumps??? Torco Manual Transmission Fluid 20WT!!! Thats right 30 yrs running 100+ mph has taught me nothing.. http://www.youtube.com/watch?v=vmaZgwauhiM
http://www.youtube.com/watch?v=dU9PMb1FvI8
If Mercury is aware of the performance of the Torco oil, which they obviously are, then why isn't that particular oil recommended for the Bravo?
Ken
minxguy is offline   Reply With Quote
Old 05-20-2009, 08:18 AM   #22
Doller Offshore
Because it's not made for longevity, like the Hi Performance green oil is. It should be changed every 50-60 hours.
John the Drive Man is offline   Reply With Quote
Sponsored Links
Old 05-20-2009, 11:11 PM   #23
Started Skater Brother
HotPursuit's Avatar
40 Skater
Quote:
Ken
Your bravo is not drysumped.. I have only run Speed Master drives,Im thinking you could if you ran the correct weight..I still perfer amsoil but Randy with Marine Drives does all my work and believes in torco after many hard hrs at high rpm&HP levels on a large hull.. The inspection of bearings and gears tell the story about how your oil holds up!! Plus drysumps run a oil filter which removes dirt and metals..
Triple Digits { T C B }
HotPursuit is offline   Reply With Quote
Old 05-20-2009, 11:21 PM   #24
Uncle Dave's Avatar
Quote:
Originally Posted by CB-BLR View Post
AMSOIL Extreme gear.
Chris
X2
(more than that so far in this thread)
I believe Imco and Teague both ship with Amsoil.
Uncle Dave
Uncle Dave is offline   Reply With Quote
Old 05-20-2009, 11:38 PM   #25
HotPursuit's Avatar
40 Skater
Quote:
Originally Posted by daredevil View Post
So ,,,do u run TORCO in the SSM's ???
Could i run it in my #4 ????
Yes in the #6s and no in your #4s. You need 80-95 weight in your wet sump #4s and would run amsoil.. If you drysumped your #4s you then could run 20wt torco..
Old 05-21-2009, 07:55 PM   #26
Rob
Strip Poker 388's Avatar
Hustler 388
Quote:
Originally Posted by John the Drive Man View Post
Never seen so many gear oil technicians.
While I was studying gynecology at MSU, the lubricity of Group I oils was found to be better and more refined of all Iso-DeWaxing process's. But also Group I had a better penetration rating with no wax and tar contents.While in school I received a certified lubricity License.Which required another 4 years of school.But I finally received all my Specifications and certifications certificates.With all that education I started my own business Personal Adult Lubricants Inc.Also known on the web as PAL's.I have processed my own blends,its a lite weight oil still has a rating of 137.09% on the Iso scale.It has the lowest certification of .012% in the friction test.It is the lowest friction oil out there.
We don't like being called technicians,we have a much higher education in BS.
Thank you
Dr. Strip
Strip Poker 388 is offline   Reply With Quote
Old 05-22-2009, 12:15 PM   #27
DRIPPINWETII's Avatar
2003 Powerquest 300 Revenge Blown 454's
Quote:
Originally Posted by RunninHotRacing158 View Post
ROYAL PURPLE BIG DADDY
We refill all the Bravos with Royal Purple max gear 75-140 good luck
I am switching to Royal Purple Why not 75-90?
Jamie
DRIPPINWETII is offline   Reply With Quote
Old 05-23-2009, 01:24 AM   #28
1 MAIDEN AMERICA's Avatar
02 38 Lightning 575SCi
How's Redline Heavy Shock Proof Oil 75W-250?
1 MAIDEN AMERICA is offline   Reply With Quote
Old 05-29-2009, 10:04 PM   #29
What speed limit???
Hang Time 27's Avatar
1981 Cigarette Squadron 27
I found it interesting that Konrad gives two different drive oil change intervals for thier drives - reg gear oil = every 200 hours, and if using royal purple, every 400 hours!!!!! Hmmmmm.........
Hang Time 27 is offline   Reply With Quote
Old 05-30-2009, 07:36 PM   #30
1994 Baja 236 500HP
Amsoil
jeffswav is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
