Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-15-2009, 04:17 PM   #1
Registered User
MOTION35's Avatar
04 SPECTRE 36 35MOTION SOLD 37 OUTERLIMTS SOLD 38GUN SOLD 30 MOTION
bravo drive oil what the best.
amsoil or mercury drive oil..opinion
MOTION35 is offline   Reply With Quote
Old 05-15-2009, 06:16 PM   #2
Chris
CB-BLR's Avatar
2009 Nordic Heat - 600sci - Whipple Stage X - SCX drive
AMSOIL Extreme gear.
Chris
CB-BLR is offline   Reply With Quote
Sponsored Links
Old 05-16-2009, 08:53 AM   #3
Got Boost ???
Smitty's Avatar
2000 Baja 36 Outlaw
Royal Purple max gear 75-140
Smitty is offline   Reply With Quote
Old 05-16-2009, 03:29 PM   #4
If it's still newer and under warranty or even just a "little bit" out of warranty then why even chance it or fight it, [IMHO] Just keep the oil's and filter's stock, Then go after market if you want to, Becouse how I see it is if you support mercruiser then mercruiser will support you in time of need in most cases. I have seen them help a lot of people out when they did not need to, It's who you ask and how you ask them that makes the differents. "Just my 02 worth"
Boat Tech is offline   Reply With Quote
Old 05-16-2009, 07:37 PM   #5
Started Skater Brother
HotPursuit's Avatar
40 Skater
Amsoil
Triple Digits { T C B }
HotPursuit is offline   Reply With Quote
Old 05-16-2009, 09:51 PM   #6
1999 Donzi 22 C
Quote:
Originally Posted by HotPursuit View Post
Amsoil
I wouldn't use any of those oils in my drive...........
That is a graph showing the viscosity of motorcycle engine oils.
Lucas is junk.
And what temp are they testing at?
Ken
minxguy is offline   Reply With Quote
Old 05-16-2009, 10:19 PM   #7
Fountain of youth
Fountain 42 Lightning 700 #6
We all use synigen red very thick less gear ware we get from donnie carter at offshore preformance they say les gear ware they number 2 or 3 largest xr drive purchaser and warranty people for mer.
gnorthga is offline   Reply With Quote
Old 05-17-2009, 12:21 AM   #8
fountainfevr's Avatar
2000 Fountain Fever
Prolly really personal prefrence I had bravo 1 fail 2 yrs ago had to replace upper gear set. I switched to Royal Purple from advice on the forums here on offshore only. I have noticed less sludge in the bottom of the resivor bottle when I change fluid in outdrive also no metal shavings on the magnets of the vent and drain plugs.( Not telling anyone to switch to Royal Purple jus giving insight on what I have noticed since I switched)
fountainfevr is offline   Reply With Quote
Old 05-17-2009, 08:24 AM   #9
birdog's Avatar
Top Gun
Quote:
Thats what i use....
birdog is offline   Reply With Quote
Old 05-17-2009, 09:50 AM   #10
H2Xmark's Avatar
1997 Fountain 35 Lightning
there are some other gear oils that might be a little better than the merc stuff but if you get a little water in the drive oil its hard to beat the merc stuff. water kills the other guys most of the time.
H2Xmark is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
