Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-15-2009, 12:55 PM   #11
TxHawk's Avatar
So you guys are mounting this in the box, not on the flywheel. I have about 80 hours on my direct bolt setup, so I am hesitant to fix something that isnt broken.
Did you notice a difference in noise / vibration?
TxHawk is offline   Reply With Quote
Old 06-15-2009, 02:17 PM   #12
1987 Scarab Panther
I believe the major benefits are the cushion you get when shifting in and out of gear and on re-entry with less than perfect throttling or in a close chop...like the water in the Great Lakes. This just is an attempt to take a drive line part that is generally used in a cruiser application to replace the Bravo rubber coupling.
You could argue that if this part isn't necessary, then maybe you don't need the Merc rubbler coupling.
BenPerfected is offline   Reply With Quote
Sponsored Links
Old 11-03-2009, 09:19 PM   #13
98 ActiveThunder Tantrum
OK, my drive made it through the season without buying this saver. Has anybody figured out which one goes in the box. I WILL be doing something with this in the off season.
My Addiction is offline   Reply With Quote
Old 11-04-2009, 09:54 AM   #14
Baja 342 Raylar HO 600's
I think the bolt patter is the same on the flywheel and on the carrier. I have 2 new in boxes if you want them.
$625 shipped - If you want pics/sizes, pm me your email.
Keith Atlanta is offline   Reply With Quote
Old 11-04-2009, 02:16 PM   #15
1987 Scarab Panther
The DS part # is correct. I will try and get you a close up picture of all the parts. I will post next week.
Old 11-13-2009, 05:18 PM   #16
1987 Scarab Panther
This shows the set up for a drive Saver using the Stellings drive shaft.
Old 11-18-2009, 04:23 PM   #17
nice pics.
I am still hopefull that I can put it in the box so I dont have to pull the motor, but haven't got around to it yet.
Old 03-22-2010, 12:08 AM   #18
OK. I attempted to put ther drive saver in,.... well I did put it in. now my companion flange carrior assembly is to long. Teague told me I may have to cut something but I cant remember what. any help?
It would also make sence that it would be too long if it were installed on the flywheel, right?
Old 03-22-2010, 12:18 AM   #19
Installed in the box only one bolt will drop, the other is about 1/2" off. not seen in pic
Old 05-01-2010, 10:25 PM   #20
For anyone who cares its all done and works great in the box. I had to take the female yoke(not pictured) to a machine shop and have the thickness of the Drivesaver cut off, and rethreaded for the seal nut. It was pretty tough to put back on the flywheel, bellhouing on motor still in boat.
note: make sure you put the shaft back together "in phase"
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
