Drive Showers not Showering
After many years of having drive showers that came with the boat when I bought I FINALLY crawled back and looked as my wife drove at cruising speed, 3500 rpm at 55 mph, trim was 5 which is slightly past level with the bottom, normal. Guess what, no water coming out of either drive shower!?!
Mr. Gadgets rebuilt my drives this year and recommended I switched them to even out the wear. Also, I had the show pickup tips welded as the following pics show. So, the pickup is now on the outboard side of the drive which is opposite than before this year's rebuild.
See the pics. Any comments???
Long time cult member.
The hull has a notched transom and the cavitation plate is about 2" above the back of the transom. The props spin outward.
Port Stbd
Port Stbd
RIPSTA Racing Team
I've always questioned the placement and depth of the shower pickups. When I changed my raw water pickups from the bottom of my hull to the rear of the transom I left one of the bottom pickups in place, ran it into a strainer, out to a #10 AN fuel "Y" to 2 thru hull fittings in the transom. From there I ran the lines to the showers. I have more water than I know what to do with. Sorry I don't have any pics but it;s pretty straight forward.
Are you sure they are not stopped up with sand, wood or other debris? Can you disconnect the hose at the top end and blow air through the hose and fitting in the top piece?
I’ve had wood get lodged in my before.
Charter Member #601
If the hoses flow freely, with air, no blockage, you may have to move the pickup to the opposite side. A quick way to check would be to swap the props from side to side and take it out for a ride, see if that helps. It should be getting water, but the prop may be stealing it. Just a thought. If water flows, then drill the opposite side of the cavitation plate and plug the other hole..
Out on the boat now. At 3500 with the drives tucked in I have flow. Trim the drives to 3 and the flow quits. Thanks for the help keep em coming.
I would swap the sides the pickups are on. The ear of the prop is travelling downward on the side the pick up is on. It should be on the "upward" swing side. It is probably pumping air down instead of pushing water up. I've run into it before.
[img][/img]
[img][/img]
Good point I will swap props and do the test again. Then look at switching the pickups to the other side of the cavitation drive.
