Quote:
Originally Posted by Uncle Dave
Agreed on cubic inches-
More is better and if big enough you can take on a big bumpstick and still have a mellow powerband.
Agreed on quality of parts as the TRUE path to sustainable high horsepower- I'm a brodix/AFR fan.
Hook and rocker are hull shape issues that cause porpoising and bow dive at speed. Your not exactly running a performance hull and its likely its not straight and true. when you have the engine out run a straight edge along the bottom and see how true it is.
Youd be surprised at how much power the imco and teague XR versions can take and what poeple have behind them lots of guys running blown big blocks on these drives. that said the beefier units are better especially with a hull that weighs that much - but lets see how much money you have before we commit 20+K to a drive.
Lightning make a SUPERB product - good choice and they know their They'll help you pick a cam.
Engines- we agree. Good heads and top end combo go a looooong way.
Trim Tabs Kiekhaffer K-planes (or similar) will stop your boat from chine walking at speed. You'll have a short heavy v with a lot of power and these will keep it stable. The longer the better.
Keep us up to date on this project - sounds like a blast - it's my favorite formula.
Boat+ money=fun
UD
Boat plus lots of money equals even more fun right.....LOL
Truth be told, Im actually the head of R&D at AFR cylinder heads (so I guess I would be partial to that brand!), but once again we seem to be on the same page....LOL.
Im putting the finishing touches on a new BBC head we are going to offer that is really going to get the job done. Its around 370 cc's (big but not huge) but flows in the 450 CFM range and does it at a usable lift point (.750 ish.....it clears 430 as early as .650). Killer piece that I plan to showcase on my 615 CID BBC destined for this boat. Still havent decided whether Im going solid or hydraulic roller....I think I could tap close to 800 even with the right hyd. set-up because this engine will be done by 6000....exactly where a hyd. roller starts giving up the ghost.
Anyway....it will be pretty cool and the ramifications of this new head design on other applications is even more ridiculous. I bet Teague picks up 50 HP when he swaps our 357's to this new head on his blower combo. I wouldnt fall over if they were worth even more on the big HP quad rotor set-up he has.
I will google search those tabs you mentioned and keep an eye out for a good deal on a strong drive. I think the fact others get away with the beefed up Bravo's stems from less weight.....boat just accelerates instead of breaking parts first. Now I will have enough grunt to accelerate the boat but we are fighting the laws of physics and the only thing in between the crazy thrust and a good prop biting water is all the components of the outdrive. No different than a heavy car breaking **** that a lighter car scoots down the track without issue with.
Before I drop 20 K though I might look for a good deal on a beefed up XR and try to be easy with my throttle. I would spend 10-12 though before grenading 5K on the XR if I run into the right deal on a Bmax, Konrad, or equivalent. Time is on my side as this project wont start till this winter and likely drag into the spring/summer of next year before its all said and done if I had to guess.
I will be boning up on high perf boat dynamics and components in the meantime....LOL
Regards,
Tony
