Speedmaster drive input to output dimension?
Does anyone know the dimension from the input shaft(crank center line) to the output shaft (prop center line) on a:
3
4
5
6
I understand a Bravo is 22 inch.
3
4
5
6
Ok, next question. What is the set back on each drive? in other words with no box's what is the distance from the forward face of the outer transom assembly to some point on the prop?
#3 should be the same ?!
Others i don't know.
