Bravo One implosion?
Why?
Did you pull the drive yet? should only take 10-20 minutes depending if you have hyd. steering to disconnect.
You will instantly know what happened.
You should check your trim limits switch. (one switch on each side of your hinge pins, unless it is a HD gimbal) One switch is for a guage/indicator and the other is the limit switch. To adjust them you lossen the two screws. You want to adjust it so it only trims up to you your know max trim height. This will stop you from ever over trimming.
To go higher you would need to use your trailer switch.
