Just curious how the boat responded, got up on plane, etc.
I started a thread recently inquiring about stronger outdrive otions for an over powered heavy boat.....LOL.....and Im considering a B-max, a Konrad, or crossing my fingers on a well prepped XR drive.....all of these being single prop applications.
Here is a link to that thread
http://www.offshoreonly.com/forums/d...plication.html
I have a typical cruiser deep V hull and currently run a BIII with a 2.2 ratio and a pair of 20P props (conservative ratio/prop set-up aimed at a low power BIII design).
More than doubling the power and the torque and looking into a single prop with a 1.35 or 1.5 ratio drive....
With a much more aggressively pitched four blade single prop do you guys think an 8200 pound boat will still plane reasonably quickly or will it blow out the single prop too easily? I dont mind a little slipping because that will help keep the drive in one piece but I want the boat to plane reasonably quickly and Im just not sure if that can be done in a single prop design in a boat that heavy but I hope it can!
Any input for others who have swapped from dual prop to single applications would be really welcomed!
Thanks,
Tony
