Arneson question
Arneson question
What sort oil do I need to run in my Armesons ASD8,s straith drives ?
There are 2 hoses coming from the units that run through the transom ,and 2 plastic containers that probably contain the oil ?? Can anybody explain how this need to be plumbed ?
Do I need to cool the oil ,and or pump it around /in and out the drive ?
Thx
Thx
arneson-industries.com
Offshoreonly Advertiser
Thx
Thx
The oil reservoir is mounted inside the boat and it is where the oil is added for the drives.
What boat do you have?
No oil cooler needed, no nothing other than the oil and the hoses. There are two fittings on the reservoir for the two hoses that are mounted to the drive to connect to. Real simple.
Rik
Arneson Surface Drives www.arneson-industries.com
Thanks Rik
The boat is a Baja 40 outlaw with 2 x 440 yanmars and 2 speed ZF transmissions 1:1 ratio in 2 th gear ,I,m still busy building this together,the boat is going to be painted in a few weeks ,and after that I ,m going to install the engines and drives.
Nope, just higher than the drive socket and you will be fine.
