rebuild it I say or use it as an opportunity to get an upgraded unit from BAM.. clutch plates pretty cheap for the velvet drive/borg warner.
there's a large ring that holds the forward clutch pack together, remove it and seperate the halves and you'll have access to the clutch plates. the reverse clutch plates will be the larger ones when you split the rear case apart.
Geronimo!!~
