Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-03-2009, 08:01 PM   #1
Drive trim Pump Question.???
My Starboard drve creeps all the way down from Trailer postion after a few days. I know it's not the rams or lines all is brand new and it worked it's way down with the old Transom assembly and rams. So It's the pump. I know there are up and down valves in the pump. So if it is creeping down what valve is failing in the pump itself, the Up or down.???
I saw the valves in a drawing I'm sure they are easy to replace.???
cocktails is offline   Reply With Quote
Old 08-03-2009, 10:03 PM   #2
83' Nordic 23' Viking 505 BBC TRS Drive
If your going to have it apart you may as well replace them both.
picklenjim is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
