Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-06-2009, 07:35 PM   #1
jimmie
hello again all im back , well i bought a bravo 3 and its leeking from between the two halfs upper and lower , it looks like its leaking frome the tube from the drive aux res , but when the out drive is up i find oil in the very front were the two halves come together , when i bought the outdrive it was off a boat that burned and it got the tube and the part that goes into the outdrive that secures the tube to the outdrive , im wondering if the part that goes into the outdrive was damaged by the heat and its makeing it leak , because i can see it leak from around the tube but would it cause it to leak from inside , the two halves and leak out between the two , any help would be appericated
jimmie is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
