Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-06-2009, 07:52 PM   #1
jimmie
hello again all im back , well i bought a bravo 3 and its leeking from between the two halfs upper and lower , it looks like its leaking frome the tube from the drive aux res , but when the out drive is up i find oil in the very front were the two halves come together , when i bought the outdrive it was off a boat that burned and it got the tube and the part that goes into the outdrive that secures the tube to the outdrive , im wondering if the part that goes into the outdrive was damaged by the heat and its makeing it leak , because i can see it leak from around the tube but would it cause it to leak from inside , the two halves and leak out between the two , any help would be appericated
jimmie is offline   Reply With Quote
Old 08-07-2009, 09:37 AM   #2
Charter Member #601
Mr Gadgets's Avatar
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
Jim,
Are you saying you have a leak where the drive mounts to the helmet on the transom assy or a leak between the upper and lower housings on the drive?
I think you are referring to the joint where it mounts to the helmet.. If so, there is a seal with a check valve (steel ball) on the drive side and the plastic fitting on the helmet that opens the check valve. If that is the area of the leak I would look at the area on the fitting that the seal sits on and see if it is round, or look for burrs on it.. that would cause a leat at that point.
Does your bottle drain when the drive is off.. It shouldnt..
Hope this helps
Dick
Mr Gadgets is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
